Everything works exept the dash lights. I checked the fuses they are ok.What else could it be??
Nov 17, 2008 at 2:15 PM
TEAG
MEMBER
You should check the bulbs. Its rare but maybe they are all burned out. Also check and see if you have current going to the bulb socket. Use a normal test light or meter to see if your getting power. If not, it may be a bad switch. Try that and see what you come up with. Good Luck :)
Dec 1, 2008 at 11:09 AM
