1987 Chevy Camaro Car won't stay running.
15,600 MILES • 6 CYL • 2WD • AUTOMATIC
GODS ANGEL
I have an 87 camaro 2.8 tpi that will start but wont stay running. I have checked and replaced the following. Its getting fire from coil to distributer to the plugs. It has full pressure for fuel on the rail at 45-47 PSI.
*THINGS REPLACED*
fuel pressure regulator.
fuel pump.
fuel pump harness.
solonoid.
battery Wires.
Fuel pump relay and fuse.
Gm Moduel (Ignition Module)
Nov 30, 2009 at 8:52 AM
  • 75,988 POSTS
Recheck fuel pressure also try cleaning out the IACV and test the TPS and MAP sensors-See below
https://images.2carpros.com/forum/automotive_pictures/12900_fp_14.jpg
Nov 30, 2009 at 9:06 AM
