I have a 1984 Chevy Camaro V6 2.8, that is hard to start, especially on cold mornings. When I start the car it will start up right away and then will shut off almost right away. I crank it again and I have to put the gas to the floor and hold it to get the car to start. The car will shake and wobble and tons of smoke will come out of the exhaust. After it starts I need to maintain the gas peddle about 1/4 down to keep it running, it takes about 5 minutes until I can let my foot off the gas.
I just recented had the carburetor repaired and it worked fine for a little while. I checked all the vacuum tubes and I increased the idol, now it goes through a tank of gas alot faster and starts up a little better at times. When cold outside or I don't run the car for a day, it becomes hard to start again.
Oct 5, 2009 at 5:45 AM
