1987 Chevy Camaro
1987 CHEVROLET CAMARO
87 CAMARO
Electrical problem
1987 Chevy Camaro 6 cyl Two Wheel Drive Manual
1987 camaro 2.8 with fule injection i can turn it over as long as i want but it wont spark untile i jack the ignition to off then it will spark once then nothin and wont work roll starting with key in eny position
May 24, 2009 at 8:32 AM
Does it crank over and will not start or just won't crank at all/nothing??
May 24, 2009 at 8:55 AM
87 CAMARO
it turns over and dose not start and has no spark untill i jack the ignition back to off then it sparkes once.
May 25, 2009 at 3:45 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
May 25, 2009 at 8:43 AM
