1986 Chevy IROC Z28 Camaro
JAKE150129
I have an 86 iroc z28 with t-tops. the milleage on the car is 129752 but not the engine. the stock engine was a 5.0 liter MFI and the original owner put a 1974 5.7 liter 350 in with a 1987 tuned port injection manifold. my problem is that the car stalls out at low speeds/at stoplights. Also I am getting around 5-7 MPG right now. It has the stock 700r4 4 speed auto in it. It only stalls out in Reverse, Neutral and Drive, but not in park. I checked the ECM and the ECM # is 1227165 with PROM 8958AMU. I can't tell if the ECM is stock 1986 or a remanufacted ECM. once the car hits about 500 rpm it starts to loop/chug and then the rpm goes down to around 250 for a minute an then stalls. Unfortunatly I can't put a scantool on it yet because I have not yet located the datalink connector. Original owner redit the entire dash/consol too. I know the 87 Iroc came with a 5.7 liter TPI and I also know the ECMs connectors for both years are the same in fact the ecm is the same ECM 1227165. I have not been able the find the PROM number for the 87 Iroc. I am wondering if I replaced the ECM and the PROM to a stock 1987 IROC Z28 that that would fix my problem. If you have any insight that would be great. also all the main sensors are plugged in.
Jul 22, 2007 at 10:25 AM
F-BODY-MASTER
Little Confused. Did you get all the tuned port accessories put on as well?
Jul 23, 2007 at 9:04 AM
JAKE150129
[quote:735cefc5d8="f-body-master"]Little Confused. Did you get all the tuned port accessories put on as well?[/quote:735cefc5d8]
I don't know, I just bought the car. What exactly do you mean by all the accessories.
Jul 24, 2007 at 9:43 AM
