86 camaro 1st and reverse good when it shifts to second there is nothing
Dec 1, 2009 at 7:35 AM
MICKEY-D
✓Experienced Mechanic
With the miles you say it has, it does not look good, but we will try. If this particular car has a kickdown cable, check the adjustment, it might not shift if it's out of adjustment. did you try driving it and shifting it manually ? Try that. I hope you checked the trans fluid by the way. Good luck. mickey-d
