Engine Mechanical problem
1986 Chevy Camaro V8 Automatic
i have a 86 camaro with a 305 tpi i got the car they said they put a new fuel pump in it so i got it home with a wrecker and starting testing...ok tested fuel preasure on rail came up 20 pounds ok then replaced regulator still 20 pounds,then i pulled fuel line off before the fuel rail and tested the pump my gage said 20 pounds for that to ok now im stumped if i spray gas into it i can get it to run it run rich and like crap when its running when i spray gas in it its wants to run good im lost on this thing..the pump,filter,and regulator are new, im lost,thanks
Jul 28, 2010 at 10:44 PM
