1986 Chevy Camaro idles fine
MR FACHINI
Engine Performance problem
1986 Chevy Camaro V8 Two Wheel Drive Automatic
car idles fine but when i open the throttle up it acts like its skipping... changed plugs, wires, distributor, TPS and nothing seems to work
May 15, 2010 at 5:19 AM
HMAC300
  • 48,601 POSTS
scan the engine for codes, then check your fuel pressure and change the fuel filter. clean the throttle plate with choke cleaner on both sides.....
May 19, 2010 at 6:48 AM
