1986 Chevy Camaro Heater/ Blower
34,499 MILES • V8 • 2WD • AUTOMATIC
SCARDOG
Heater/ blower dos not work at all. Have replaced the heater blower, switch and relay but blower does not ocme on. what else can i check to make the heater blower work??
Jan 5, 2008 at 11:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:7f28dadd43="scardog"]Heater problem
1986 Chevy Camaro V8 Two Wheel Drive Automatic 034499 miles
Heater/ blower dos not work at all. Have replaced the heater blower, switch and relay but blower does not ocme on. what else can i check to make the heater blower work??[/quote:7f28dadd43]
you need to check if you have power at the blower motor 0ne wire have to have battery power
place switch at high
other wire should have ground at it
check that let me know
what missing and we go from there
Jan 5, 2008 at 12:04 PM
MASTERTECHTIM
  • 4,750 POSTS
if you have no power check under hood to the left and rear of engine there is a harness with a 10 gauge red wire, you will see where the fat red wire connects to another fat red wire, there is a black connector where both wires connect. try disconnecting the connector and see if its burnt. if it is bypass the connector and you should be ok.
Jan 5, 2008 at 12:10 PM
