Engine Performance problem
1986 Chevy Camaro V8 Two Wheel Drive Automatic
please help im trying to fix a 1986 camaro with a tpi it is hard to start cold or hot seems to be flooded have to hold throttle open to clean out then it throws a 33 code have replaced maf , tps , maf relay, cleaned and inspected maf relay connector and fuel pump realy and connector have installed a new regulator, new injectors, holds fuel pressure pretty good now was losing presure fast before and injectors were noisy set tps at 5.4 volts yet still it starts hard cold or hot , if you fire it right back up its ok if it sits five or so min its hard to start again , please help me
Aug 7, 2008 at 1:40 PM
