1986 Chevy Camaro engine locked up
156,004 MILES • 6 CYL • 2WD • MANUAL
SPOOK2009
would like to change to a 350sb wanted to know if factory transmission will bolt
Sep 8, 2009 at 12:01 PM
HMAC300
  • 48,601 POSTS
The trasmission should bolt up but you need to be sure the flywheel housing does. The V6 will have a different flywheel housing. You computer will need to be updated or matched for the small block as well..
Sep 14, 2009 at 11:03 AM
