1986 Chevy Camaro
135,000 MILES • V8 • 2WD • AUTOMATIC
GRACIE819
if the fuel pressure regulator is bad will it cause gas to leak into the oil pan? the motor is a 305 tune port motor
Feb 23, 2009 at 7:30 AM
DOCFIXIT
  • 18,828 POSTS
Itcan pull vacuum hose off reg any gas in it? If not then leaking injectors maybe at fault.
Feb 23, 2009 at 7:45 AM
