1985 Chevy Camaro t.p.i to carb swap ??
SKINNERBOY
Air Conditioning problem
1985 Chevy Camaro V8 Two Wheel Drive Automatic
do i need to keep the computer to use my ac ? i removed the tuned port injection due to all the problems i was having with it . i noticed all the wires that went to the a/c came from the passenger side harness ( computer harness ) and would like to know what i need to do to use my a/c again ?
Jan 11, 2010 at 9:53 AM
BLACKOP555
  • 10,386 POSTS
yes you have to have it hooked up to the computer and the wirings intact. why exactly did you remove teh computer also. it controls spark timing too does it not?
Jan 11, 2010 at 11:30 AM
SKINNERBOY
i removed the tuned port injection due to all the problems i was having and replaced it with a carb set up and vacume advanced distibutor . the computer is still in the car and all the wilres are intact . can i just use the wires for the a/c or is there other things that have to work together for the ac to work .. ie fuel injectors , relays .
Jan 11, 2010 at 11:47 AM
BLACKOP555
  • 10,386 POSTS
you should leave your sensors up. wont hurt anything or change anything since you have everything disconnected. so your ac doesnt work after you ripped stuff out? wat did you all remove?
Jan 11, 2010 at 2:45 PM
