1985 Chevy Camaro starting
1985 CHEVROLET CAMARO
DFACKLER
Engine Mechanical problem
1985 Chevy Camaro 6 cyl Two Wheel Drive Manual
Car will turn over but will not tempt to start. I have replace the coil and module. I have checked and the coil is getting power when the key is on. I checked the contunity of the pick up and it is good. I am getting fuel and spark.
Dec 2, 2009 at 12:25 PM
MICKEY-D
  • 304 POSTS
If you are getting fuel and spark, the car should run. You wrote that you checked several things for power or continuity with the key on, but you never mentioned if you checked anything while the engine was cranking over. have someone crank the engine and see if you have spark at any plug wires. If you do, give it a shot of starting fluid, and see if it runs. If it does, you have a fuel pressure issue. hope you can use this info to fix your problem, good luck.
mickey-d
Dec 4, 2009 at 2:35 PM
