1985 Chevy Camaro Engine overheat in the desert
150 MILES • 6 CYL • 2WD • AUTOMATIC
ERIC_S
This engine is new but always overheats at first fan didn't work now I've fixed this but the radiater doesn't start circulating until the gauge is in the red.
What I've done:
Fixed Fan
Replaced thermostat (several times)
Replaced wiring for the thermostat all the way back to firewall.
Thank you for your time
Eric
Oct 12, 2010 at 5:42 AM
  • 75,988 POSTS
Check if the radiator is clogged and water pump is functioning
Oct 12, 2010 at 6:54 AM
