1984 Chevy Camaro Ignition Switch
DEVILZSPAWN
Electrical problem
1984 Chevy Camaro V8 Two Wheel Drive Manual
I turn the key and get no juice. The power seats, headlights, and power window work tho. Is this a bad Ignition Switch or should i be looking somewhere else. I traced back all the electrical in the engine compartment and it all seems to be live until it gets into the cab.
Jul 5, 2009 at 10:35 AM
LOUT5369
  • 217 POSTS
Gm sometimes has a fuse in a case near the battery,check that fuse,also in the fuse panel see if it has a crank fuse,if it does check it,you may have a bad starter.good luck,Lou
Jul 22, 2009 at 4:27 AM
