1984 Chevy Camaro Correct Fluid
BOB KERNOHAN
Transmission problem
1984 Chevy Camaro V8 Two Wheel Drive Manual
My 1985 Camaro with T5 manual transmission has a hard shift 1-2, I have heard lts of info about different fluid to use the latest is to use GM synchromesh fluid. I have heard good things about Redline D4-ATF and Redline MTL. The car is original with 40K miles. THE fulid was changed using ATF when I first got it 4 years ago.
Mar 27, 2009 at 4:57 AM
DOCFIXIT
  • 18,828 POSTS
Hard shift ? do you mean difficult to move shifter? will not engage 2 gear without force? any noise associated?
Mar 27, 2009 at 9:25 AM
BOB KERNOHAN
The shift is harder going into 2nd than 3rd 4th or 5th. There is no noise, shifter moves freely,, just harder to actually engage.
Mar 27, 2009 at 11:23 AM
DOCFIXIT
  • 18,828 POSTS
I have an 84 Z28 got it new was hard to shift also. If you tried to shift fast no go. Had to dealer many times no help. I installed a Center Force clutch and problem solved better acceleration and could shift like lighting. As you tried different fluids and additives no improvement. Hope this helps.
Mar 28, 2009 at 2:38 AM
