1984 Chevy Camaro altanator
CHANCEY
Engine Mechanical problem
1984 Chevy Camaro V8 Two Wheel Drive Automatic
my altanator onley charges when i put the left wire facing in front of the car on the battery.My battery goes dead over night when i hook that wire back up
Feb 28, 2009 at 3:27 AM
JDL
  • 16,098 POSTS
Hello, the brown wire at the connector should be excite voltage. Without that the alternator won't charge. If the alternator is causing the battery to run down, it may be a faulty diode.
Any wire your talking about, can you give us the wire color?
Feb 28, 2009 at 4:05 AM
