1984 Chevy Camaro
PBR1986
  • 5 POSTS
Brakes problem
1984 Chevy Camaro V8 Two Wheel Drive Manual
My brake lights dont work at all, iv looked at the fuses and the bulbs and they are all fine, why do i not have any brake lights?
Nov 12, 2009 at 5:29 AM
JDL
  • 16,098 POSTS
welcome, check for voltage at the brake switch. Orange wire is hot all the time. White wire goes hot when the switch is activated. The brake lites are wired through the turn signal switch, the brake and turn lite use the same bulb filament, just not at the same time. Did you check voltage and ground at the bulb socket?
Nov 12, 2009 at 7:18 AM
PBR1986
  • 5 POSTS
where would the brake switch be? i have turning signals on the front and back, and all my running lights are working, just not the brakes.
Nov 13, 2009 at 8:11 AM
JDL
  • 16,098 POSTS
The switch should be activated by the brake pedal arm. Follow the brake pedal arm, upward.
Nov 14, 2009 at 12:08 AM
PBR1986
  • 5 POSTS
Now i am having some problems with my radiator, when i let it run for about 5 minutes, the radiator resivoir anti freeze boils over with alot of steam, its not the water pump, and its not the thermostat.
Need a little help diagnosing the problem.
Nov 15, 2009 at 11:46 AM
JDL
  • 16,098 POSTS
I'd take the thermostat out, hook everything back up, just for testing. See if there is coolant flow through the radiator. It is a possibility you could have a cracked head or something?
Nov 16, 2009 at 12:42 AM
PBR1986
  • 5 POSTS
i already tested the thermostat by boiling it, i just put in a new water pump, i drained and flushed the radiator, water flowed through well. i checked th fluid that come out of the radiator and there was no sign of oil in it and i checked the oil and there was no coolant in it.
Nov 16, 2009 at 7:54 PM
JDL
  • 16,098 POSTS
You may have to check for combustion gases in the radiator? Other than that, I don't know?
Nov 17, 2009 at 12:34 AM
PBR1986
  • 5 POSTS
Could the coolant temperature sensor being out make the car overheat?
Nov 20, 2009 at 7:47 AM
