1983 Chevy Camaro Starter solenoid
OHMAN5715
Engine Mechanical problem
1983 Chevy Camaro V8 Two Wheel Drive Manual
Today I drove my camaro, and it started and ran fine. When I went to start it again, I had no power at all, but I had power for my lights. I checked the battery with a tester and it had plenty of power, so I decided it was the starter. I tried to pop the clutch to get it started, but nothing happened after several tries. Could this be a stuck solenoid preventing the motor from turning over as well as preventing the starter from running?
Jun 6, 2010 at 12:24 PM
  • 75,988 POSTS
Be careful here-short out the purple wire on the solenoid to the battery terminal at the starter-did it crank the engine over -if not its gone.
Jun 6, 2010 at 12:29 PM
