1983 Chevy Camaro mater cylinder
1983 CHEVROLET CAMARO
V8 • 2WD • AUTOMATIC
DRZ28LS1
on my mater cylinder, i have two lines that come out. Which line or both are for the front brakes? Thank you, very much!!! Kurt
Jul 27, 2010 at 2:23 AM
HMAC300
  • 48,601 POSTS
if you have on side of the master that is larger than the other meaning bowl size then it's the line on that side. If they are both the same it should be the rear line (closest to firewall or booster).
Aug 2, 2010 at 11:37 AM
