ok I have a 1983 berlinetta camaro with a v8 305, and I started the car the other day to warm it up before I took off, well I went back in the house and about 15 min later went back out and noticed the car was smokin from the passanger side and I went to cut the car off and when I did I noticed that antifreeze had leaked into the car (and had leaked on the ground outside also) so I figured it was a hose, so I checked the in feed and out feed hose for the heater and both hoses are good, so do you have any idea what this could be?
Jan 20, 2009 at 8:13 AM
