1983 Chevy Camaro Fuel Leak
1983 CHEVROLET CAMARO
CBKATTELMAN
Engine Mechanical problem
1983 Chevy Camaro 6 cyl Two Wheel Drive Automatic
I have a 1983 Chevy Camaro v6 2.8 ltr I noticed that is was leakinf fuel when it was idling from underneath the carburator it would stp leaking when driving though. I just replaced the fuel filter thinking maybe since it had been sitting up for a while that the gas had clogged the filter and just putting to much pressure on the it causing it to leak. But alas it still leaks where are the possible places fuel can leak from the beneath the carburator?
Apr 20, 2009 at 1:55 PM
TEAG
  • 158 POSTS
Check your fuel lines going into the carb. Maybe one is bad or loose. Make sure theyre not cross threaded and tight. Good luck. :)
Apr 25, 2009 at 9:56 AM
