1981 Chevy Camaro oil and the right heads?
106,000 MILES • V8 • 2WD • AUTOMATIC
ZDERBOY
I would like to change my oil from regular oil to synthetic oil, and I'm not too sure what to use 10w 30 or something higher I have a comp cam kit and Edlebrock intake with a holley 670 cfm carb, cheap headers, what would you recomend synthetic or not and what weight oil. Also I would like to upgrade my heads what should i look for in heads for a 350small block.
Jan 9, 2010 at 5:19 AM
ERNEST CLARK
  • 1,730 POSTS
Upgrading to full-synthetics is always a good idea, so long as you can afford it.
10w30 would be just fine for your engine.
Now having said that, it's not a good idea to do performance mods on a motor with over a 100K miles on it. You'd be improving the power output of a motor that barely wants to make the power it was designed to make!
I'd recommend first doing a complete overhaul of the bottom end, then think about performance.
As for performance heads, the sky's the limit. As the old saying goes: How fast do you want to go???
Also, your choice will depend on if your engine is carbed, or injected.
If you keep your Edlebrock cam/intake/carb combo, then I'd suggest getting a pair of their heads. They'll perform as a system and you can't go wrong!
Jan 13, 2010 at 1:33 AM
