1981 Chevy Camaro No voltage when I hook up the compressor
1981 CHEVROLET CAMARO
20,500 MILES • V8 • 2WD • AUTOMATIC
JEFFREY D ROBERTS
Hi-I just charged my a/c system and it blows cold air but i have to hot wire the compressor with a positive battery lead.
Otherwise the compressor will not turn on.
There is voltage going to the leads that connect to the compressor but when I connect it there is no voltage and the compressor will not turn on.
Is it a relay?
Please help-I'm close on this I think.
Why wouldn't the compressor kick in if there is voltage and then when I connect it there is no voltage?
I'm thinking a bad relay-where do i go from here?
Sep 7, 2009 at 11:10 AM
HMAC300
  • 48,601 POSTS
Even if there is voltage going to operate the compressor, it has to complete the circuit by grounding out to operate. If you already have power going to it, it sounds as it is not completeing the circuit. That system will have either an expansion valve with a small tube going to the evaporator or a pressure switch. the pressure switch should be by the evaporator. to check this disconnect the switch electrical connector and jump it. If the compressor kicks on then there in may lie your problem. If it is an expansion valve then it will also have a connector there to do the same thing. If it has an expansion valve the system will need to be discharged to repair. If it's a switch it should have a schrader valve behind it so the system won't have to be discharged. Always be careful with a/c systems as you are usually dealing with high pressure and it should be discharged correctly and recycled. Also on these cars, make sure there is a good ground wire going from the firewall to the engine. If not it will melt your transmission cable and you will start your car in what you think is park and is actually drive.
Sep 8, 2009 at 10:59 AM
