1980 Chevy Camaro Stalls at Idle and higher RPM
89,900 MILES • 6 CYL • 2WD • MANUAL
MATT MAURER
What could be causing this car to stall at idle and at speeds around 25 mph. I just bought this car for my son and I to restore. Car usually starts after I pump the gas pedal several times. I have turned up the idle to keep it from cutting out. When I increase speed to shift into 3rd (3spd manual) it runs a bit but then cuts out totally and won't start for a few minutes. Parts guy said Idle Air Control Valve. I'm not sure.
Aug 19, 2009 at 3:06 PM
  • 75,988 POSTS
Go ahead and clean out the idle air control valve and test the TPS and MAP sensor to include a fuel pressure check.
Aug 19, 2009 at 7:25 PM
