1980 Chevy Camaro carbutrator
4,000 MILES • V8 • 2WD • AUTOMATIC
KALEBJSKI
i have a holly 750 dbl pump carburator. i seem to be having a problem with the inlet needle! it spews gas out of only one of the two inlet needles. not a leak it spews out of the top of the carb. what might be ther problem?
Thanks, Kaleb
Feb 16, 2009 at 8:07 AM
RACEFAN966
  • 5,029 POSTS
I would say that other is pluged and needs to be cleaned out. It will need to be removed to see if you can run a welding tip cleaner rod up through it. Then spray it really good with carb cleaner and air and that should do it.
Feb 16, 2009 at 1:36 PM
