1980 camaro stalls in gear
SLYASH50
Hey i recently replaced the engine from a 305 to a 350 bored .40 over it seems to want to stal when i put it in gear un less i give it gas to keep it alive. also it wants to take off but when i push the gas it doesnt excelerate very fast. i was thinking torque converter?
May 15, 2006 at 3:41 AM
LOSONE
  • 1,616 POSTS
If it has a high stall torgue converter it may be the problem but on the offset it sounds like a carb problem to me.
May 15, 2006 at 10:30 AM
SLYASH50
the torque converter is stock i was thinking i needed a higher stall like 2300 or so. because it idles fun and what not but just when i put it in gear.
May 15, 2006 at 1:40 PM
LOSONE
  • 1,616 POSTS
It may idle funy because you might have a little more than stock cam. Funny idle is also caused by a vacuum leak. Good luck
May 17, 2006 at 12:50 AM
