1979 Chevy Camaro Water Pump Removal
CHRISBER
Engine Cooling problem
1979 Chevy Camaro V8 Two Wheel Drive Automatic
What tools do I need for Water Pump removal on a 1979 Camero. I noticed when you get to the step of loosening the power steering pump, the bottom bracket nut has an different shape to it...seemingly a shape that would require a crecsent wrench. However the area is very tight fitting and does not appear to leave any room for any good torque in order to loosen it. Would I need a special wrench for this process?
Thanks.
Feb 5, 2009 at 3:22 AM
BOWTIE BABY
  • 101 POSTS
I have owned and worked on a lot of Camaros and ive never seen that, its probably modified or damaged. If you try fitting a socket on it im sure you will find one to fit. When you get it out inspect the bolt for damage and replace it if it doesnt look original.
Feb 5, 2009 at 5:45 PM
