1979 Chevy Camaro oil leek
PAGE523
  • 5 POSTS
Engine Mechanical problem
1979 Chevy Camaro V8 Two Wheel Drive Automatic
I have a 454 and I think I need a diagram for the interor drivers side of block with any hole that goes to the oil shown; it arterialy bleeds oil in a spray about the diamiter of ones pinkey, leading me to beleve I have lost a plug for a sensor. I can't see the area due to the motor being in the car so if you can a diagram and prognosis check would be helpful.[img:980efc423b]http://www.2carpros.com/forum/automotive_pictures/329114_b2de_1_1.jpg[/img:980efc423b]
Mar 9, 2009 at 4:41 AM
DOCFIXIT
  • 18,828 POSTS
Oil pressure switch on that side of block. Try using inspection mirror to see. You runnig a mechanicl oil pressure gague?
Mar 10, 2009 at 3:47 AM
PAGE523
  • 5 POSTS
It's a first gen 454 so it had mec. one but I beleve it has been changed to ele. I beleve I have lost a plug bolt the size of the sensor. I need to know the size said "bolt-sensor" so I can replace it. a diagram would help with that, unless someone knows the bolt I need. at 10 cents per bolt I'd be OK a few answers. Help.
Mar 11, 2009 at 11:51 AM
DOCFIXIT
  • 18,828 POSTS
1/4 in. pipe thread
Mar 12, 2009 at 6:44 AM
PAGE523
  • 5 POSTS
what is the name of the missing part under the torque converter in the attached pic and does it hold in trans fluid? (not my car just a good pic of the part)
https://images.2carpros.com/forum/automotive_pictures/329114_LEVY40020027_1.jpg
Mar 19, 2009 at 3:36 AM
DOCFIXIT
  • 18,828 POSTS
A flywheel cover
Mar 19, 2009 at 5:31 AM
PAGE523
  • 5 POSTS
napa.com has never heard of a flywheel cover. is there another name? also does it retain trans fluid?
Mar 19, 2009 at 3:08 PM
DOCFIXIT
  • 18,828 POSTS
Dealer or bone yard part. No fluid just keeps debris from torque convertor and front oil seal
Mar 20, 2009 at 3:59 AM
PAGE523
  • 5 POSTS
Ok so heres the deal when I shift from park into reverse it drives but after neutral it just does nothing it is full of trans fluid and I can here it moving something when I shift the stick around. and it is an auto. help?
Mar 30, 2009 at 12:32 AM
DOCFIXIT
  • 18,828 POSTS
So you have reverse but no drive? Place in neutral then ckeck shift lever on trans there is a hole in lever that must lineup with hole in trans. Adjust if needed. if not that drop pan and check manual shift valve to lever see if it moves spool valve.
Mar 30, 2009 at 9:25 AM
