1979 Chevy Camaro no electrical at all
100,000 MILES • V8 • 2WD • AUTOMATIC
DCS1242
hello i have a 1979 Z28 camaro 350 engine, i have this electrical problem i guess. well when i turn my ignition switch i get no power no voltage, nothing at all lights dont turn on i mean nothing at all, and the engine does not turn over or crank. so i took the starter and battery off and took it to be check, turned out to be that the starter was good but the battery was not so i got a new battery.so i replaced the old battery for a new one and put the startwe back on and tried to start the car again and the same thing happened. the engine would not turn over or crank, i have no power or voltage. so what do think is the problem if you can give as much as possible information to get my car working
May 14, 2010 at 5:08 PM
  • 75,988 POSTS
Check and test all the fusible links at the starter if okay test the ignition switch
May 14, 2010 at 11:07 PM
