1979 Chevy Camaro Headlight switch dimmer for courtesy ligh
JOHNS79Z
  • 6 POSTS
Electrical problem
1979 Chevy Camaro V8 Two Wheel Drive Automatic
Does the reostat on the headlight switch that
controls the dim to bright use a positive voltage
i.e. 12volts or does it control ground?
Thank you
John B.
Apr 9, 2009 at 1:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Thanks for the donation Below is a partial wiring diagram of your vehicle's dimmer switch and headlight switch. Let me know if you need further assistance..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_434.jpg
Thanks for using 2CarPros.com!
Apr 9, 2009 at 4:31 PM
JOHNS79Z
  • 6 POSTS
Thank you for the quick response
The diagram is so small I can not read it
can it be made a little larger?
Thank you for your time
Sincerely
John Burkhalter
burkhaltej@sbcglobal.net
Apr 10, 2009 at 3:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
I will email the diagram to you. This will allow you to use a ZOOM feature from your computer.
Apr 10, 2009 at 5:36 AM
JOHNS79Z
  • 6 POSTS
Thank you for your reply
John
P.S. it shows I have only .1 points if I change it to
1 it says I can't.I don,t know to do this I guess
Apr 10, 2009 at 6:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry about that John. We are currently working on a new points system for feedback. For now, you can contact one of the administrators and let them know how you feel about the service here at 2CarPros.com. An email address is below if you would like to do this..
mike@2carpros.com
Apr 10, 2009 at 7:02 AM
