1979 Chevy Camaro battery drain
JIMPOWELL
  • 1979 CHEVROLET CAMARO
  • V8
  • 150,000 MILES
I have a slow battery drain test light half lit key off ive pulled the fuses, dont help. Maybe alternator or ignition?
Friday, December 21st, 2007 AT 2:27 PM
MERLIN2021
  • 17,250 POSTS
Get an analog voltmeter remove the negative battery cable, attach the red lead to the battery post, black lead to cable end, then pull fuses one at a time, make sure there are no accessories or lights in the on position, Key off! Close the door after each fuse and check meter, when you pull the fuse for the bad curcuit, the meter will drop to 1 volt or so. Check all fuses, even under the hood. If meter does not drop, remove the battery connection from the alternator, if it drops now, the diodes are bad in the alternator. Put the fuse back in were it goes as you go so you don't forget which fuse goes were!
Friday, December 21st, 2007 AT 3:55 PM
