1979 Chevy Camaro 79 Camaro dies when gas is applied
79CAMARO88
  • 18 POSTS
It the stock hei ignition
Saturday, September 5th, 2009 AT 2:16 PM
DOCFIXIT
  • 18,828 POSTS
Pull a plug wire hold 1/4 inch from block. Crank is spark blue/white and cracks? Pull coil cover off remove coil look for any carbon arching especialy at ground strap.
Saturday, September 5th, 2009 AT 2:22 PM
79CAMARO88
  • 18 POSTS
Well I looked and the doesn't seem to be any carbon tracking or arching any where. The spark is a white blue color. Any more ideas?
Monday, September 7th, 2009 AT 10:32 AM
DOCFIXIT
  • 18,828 POSTS
Remove control module in Dist. Take to Auto Zone have it tested. Does Dist have vacuum advance?
Monday, September 7th, 2009 AT 12:44 PM
79CAMARO88
  • 18 POSTS
Yes it has a vaccumm advance.
Monday, September 7th, 2009 AT 6:51 PM
DOCFIXIT
  • 18,828 POSTS
There should be NO vacuum at idle if O.K. Check weights under Rotor are they free. Did you have module tested?
Tuesday, September 8th, 2009 AT 2:03 PM
79CAMARO88
  • 18 POSTS
No I have not tested it yet. I cant check vaccumm because every time I pull the hose off the engine kills. I'll check to see if the weights are free. Thanks!
Thursday, September 10th, 2009 AT 6:51 PM
79CAMARO88
  • 18 POSTS
Yes the weights are free
Thursday, September 10th, 2009 AT 7:02 PM
DOCFIXIT
  • 18,828 POSTS
Pull off vacuum line plug loosen Dist advance enough to, keep running. Set timing. Next find port on casrb that has NO vacuum at idle but vacuum above 1000RPMS
Friday, September 11th, 2009 AT 3:10 PM
79CAMARO88
  • 18 POSTS
I think I have a big vaccumm leak at idl3 I have between 8-10 inches of mercury. Thats pretty low correct? And that would account for it dying when put into gear.
Tuesday, September 15th, 2009 AT 9:00 PM
DOCFIXIT
  • 18,828 POSTS
Are you checkig vacuum at a port on intake? If yes the needs to be like 15 20 in. Reading indicates late valve timing so maybe issue with cam instalation.
Thursday, September 17th, 2009 AT 8:31 AM
