1979 Chevy Camaro 79 camaro dies when gas is applied
138,000 MILES • V8 • 2WD • AUTOMATIC
79CAMARO88
  • 18 POSTS
hi i have a 79 camaro with a 305. i recently put a new cam in it. a comp cams 268H. anyway i have set ignition timing to 4 degrees btdc like the spec says. i have set the fast idle a curb idle to spec as well. i have a new fuel filter and new choke pull off. new float, needle and seat. the flot i have set to i believe 5/16. now it starts and runs pretty well. i can put it into gear and it will roll. but when i step on the gas in drive or reverse it will die. i was wondering what could make it do that. (also i did this stuff with no air cleaner attached) dont know if that would make a difference. ( the carb is a rochester dual jet) thanks for the help!
Aug 8, 2009 at 6:32 AM
BUDDYCRAIGG
  • 2,262 POSTS
can you give it gas slowly?
Maybe the plunger is bad, or you didn't get it hook back up right.
Aug 8, 2009 at 10:25 AM
79CAMARO88
  • 18 POSTS
thanks for the reply. yes i can give it a little gas slowly. is that a sign of a bad plunger? thanks again!
Aug 8, 2009 at 11:10 AM
BUDDYCRAIGG
  • 2,262 POSTS
with the engine off and the air cleaner removed.
look down inside the carb,
when you open the throttle quickly, you should see a stream of fuel from a small brass tube up high in the throat.
But i bet that you will not,
either the plunger is bad,
the tube is plugged.
you didn't get that little BB check ball back in place
or the linkage is not hooked up right.
Aug 8, 2009 at 11:15 AM
79CAMARO88
  • 18 POSTS
ok i looked down inside and when i snap the throttle 2 streams of fuel shoot out in to each barrel.. i do see some brass tubes in the middle of each barrel but no fuel comes out of those. are those the tubes you are talking about? .....and are you talking about a TPS plunger? because i don't think i have one.. and are you saying the throttle linkage might not be right?? or the choke linkage and stuff like that?
sorry about all the questions..this really helps me alot i appreciate this very much. im trying to learn about carbs..they don't teach it in school anymore.. thanks again!
Aug 9, 2009 at 3:57 AM
BUDDYCRAIGG
  • 2,262 POSTS
I'm going to cut your question up in to smaller parts
[quote:325629163d="79camaro88"]ok i looked down inside and when i snap the throttle 2 streams of fuel shoot out in to each barrel.. and are you talking about a TPS plunger? because i don't think i have one.. and are you saying the throttle linkage might not be right?? or the choke linkage and stuff like that?[/quote:325629163d]
Ok, since you get those two streams of gas, then the accelerator plunger is working, And I was talking about the linkage that depresses the accelerator plunger.
[quote:325629163d="79camaro88"] i do see some brass tubes in the middle of each barrel but no fuel comes out of those. [/quote:325629163d]You should have fuel coming out of those when the throttle is open.
Either there is a blockage, or you dont have the float height set right.
Aug 9, 2009 at 10:41 AM
79CAMARO88
  • 18 POSTS
alright thank you so much for all your help! i appreciate it. i'll see if there are any blockages in those tubes. and just to clarify i should see fuel coming out of those when the throttle is open while the engine is off or running?
Aug 10, 2009 at 12:20 AM
BUDDYCRAIGG
  • 2,262 POSTS
[quote:322a2f34b8="79camaro88"]and just to clarify i should see fuel coming out of those when the throttle is open while the engine is off or running?[/quote:322a2f34b8]
OOPS.
when it's running.
Aug 10, 2009 at 2:30 AM
79CAMARO88
  • 18 POSTS
ok well i'll check for that. asap, thanks very much
Aug 11, 2009 at 12:23 AM
BUDDYCRAIGG
  • 2,262 POSTS
be careful not to be directly over the carburetor.
If it back fires with you right over it, it will burn off your eye brows and possibly hurt your vision.
Aug 11, 2009 at 6:47 PM
79CAMARO88
  • 18 POSTS
well i looked down the tubes. and cleaned them out. theres no blockage in the tubes. so that would men incorrect float height. correct? would it be to low or to high? thanks
Aug 12, 2009 at 1:16 PM
BUDDYCRAIGG
  • 2,262 POSTS
too low
Aug 12, 2009 at 6:48 PM
79CAMARO88
  • 18 POSTS
ok well the float level was at 9/32 from the infromation i have gathered i need it at 15/32. does that sound right? i cant find any specs on this carb. the number is 17059136. thanks
Aug 22, 2009 at 4:24 AM
BUDDYCRAIGG
  • 2,262 POSTS
your float height information should have come with paper work in the carb rebuild kit you used.
Aug 24, 2009 at 2:12 AM
DOCFIXIT
  • 18,828 POSTS
Hi
That's a really agressive wamp stick you put in. Did you get kit or just cam? and your running stock intake manifold with a 2-bbl? stock ignition? Headers?
Aug 24, 2009 at 3:00 AM
79CAMARO88
  • 18 POSTS
i got the cam and lifters with chain and new cam sprocket. and yes stock manifold and stoch exhaust manifolds. with stock HEI ignition. got any ideas?
Aug 27, 2009 at 11:54 AM
79CAMARO88
  • 18 POSTS
i have bought 3 different rebuild kits and they don't list this carb. all i can find are specs on other carbs. looking my sheet over i saw that mast vehicles in 1979 with a 305 had a 15/16 float level
Aug 27, 2009 at 4:23 PM
DOCFIXIT
  • 18,828 POSTS
Don't think float level is problem. Is this a 2 BBl carb E2M series? If yes not ehough CFM for that cam.
Try advancing timing say 8 ATDC
Aug 28, 2009 at 1:43 AM
79CAMARO88
  • 18 POSTS
it is a rochester dualjet 210 (M2MC, M2ME) series. so no its not a E2M. i believe the E2M have and electrical connector somewhere ..correct? thanks again guys!
Aug 28, 2009 at 12:24 PM
79CAMARO88
  • 18 POSTS
well i tried 8 degrees and it didn't work. i wouldn't run for more than about 30 seconds..so then i tried 10 degrees and 12...and no luck threr either. any other ideas?? thanks
Sep 5, 2009 at 6:52 AM
DOCFIXIT
  • 18,828 POSTS
What type ignition system ?
Sep 5, 2009 at 7:13 AM
79CAMARO88
  • 18 POSTS
it the stock hei ignition
Sep 5, 2009 at 7:16 AM
DOCFIXIT
  • 18,828 POSTS
Pull a plug wire hold 1/4 inch from block. Crank is spark blue/white and cracks? Pull coil cover off remove coil look for any carbon arching especialy at ground strap.
Sep 5, 2009 at 7:22 AM
79CAMARO88
  • 18 POSTS
well i looked and the doesn't seem to be any carbon tracking or arching any where.. the spark is a white blue color.. any more ideas??
Sep 7, 2009 at 3:32 AM
DOCFIXIT
  • 18,828 POSTS
Remove control module in Dist. take to Auto Zone have it tested. Does Dist have vacuum advance?
Sep 7, 2009 at 5:44 AM
79CAMARO88
  • 18 POSTS
yes it has a vaccumm advance.
Sep 7, 2009 at 11:51 AM
DOCFIXIT
  • 18,828 POSTS
There should be NO vacuum at idle if O.K. check weights under Rotor are they free. Did you have module tested?
Sep 8, 2009 at 7:03 AM
79CAMARO88
  • 18 POSTS
no i have not tested it yet. i cant check vaccumm because every time i pull the hose off the engine kills. i'll check to see if the weights are free. thanks!
Sep 10, 2009 at 11:51 AM
79CAMARO88
  • 18 POSTS
yes the weights are free
Sep 10, 2009 at 12:02 PM
DOCFIXIT
  • 18,828 POSTS
Pull off vacuum line plug loosen Dist advance enough to ,keep running. set timing. next find port on casrb that has NO vacuum at idle but vacuum above 1000RPMS
Sep 11, 2009 at 8:10 AM
79CAMARO88
  • 18 POSTS
i think i have a big vaccumm leak at idl3 i have between 8-10 inches of mercury. thats pretty low correct?? and that would account for it dying when put into gear.
Sep 15, 2009 at 2:00 PM
DOCFIXIT
  • 18,828 POSTS
Are you checkig vacuum at a port on intake? if yes the needs to be like 15 20 in. Reading indicates late valve timing so maybe issue with cam instalation.
Sep 17, 2009 at 1:31 AM
