Engine Mechanical problem
1978 Chevy Camaro V8 Two Wheel Drive Automatic ??? miles
I have a 92 camaro that has a 350 sbc out of a 78 camaro. I just recently got the car so I dont know much about it. I was driving the other day and A lifter started tapping. Got it home pulled the valve cover to adjust the rocker arm, when I noticed that there wasnt a jam nut on the rocker arm just a regular nut. I went and purchased a new rocker arm and jam nut. Put it on and adjust the rocker arm with the motor running. I can adjust it so it will quit ticking but within a few seconds of the motor running it starts to tick again. I pulled the pushrod and it was bend so I replaced it but still having the same problem can adjust it till it quits and motor idles down but within a few seconds motor will idle back up and starts tapping again. Any sugjestions???
Apr 23, 2009 at 11:14 AM
