1978 Chevy Camaro ACCESSORIES
115,000 MILES • V8 • 2WD • AUTOMATIC
DLPCAR
My accessories do not come on (no power I presume) when I start my car, starter works and motor runs but no power to gauges, wipers, etc. All fuses are fine, cant find any loose or broken wires. I used to be able to jiggle key in column and they would work, but no longer.
May 19, 2008 at 9:14 AM
MERLIN2021
  • 17,250 POSTS
The switch may need adjusting, with the two 5/16th screws that hiold it to the column, or the switch should be changed, not the key but the plastic switch the harness plugs into.
May 19, 2008 at 9:17 AM
