1977 Chevy Camaro
RWALKER
  • 1977 CHEVROLET CAMARO
1977 Chevy Camaro V8
I have a leaking freeze plug on the drivers side of the engine. How do I remove and replace this with the engine in the car?
Sunday, June 14th, 2009 AT 8:35 PM
  • 109,885 POSTS
When removing, take a screw driver, punch a hole in the center and pry it out. When replacing it, I center it, take a small block of wood, and tap the new one in. They also make a rubber one for replacement if you are in a tight area. It has a bolt on it that when tightened expands the rubber fixing the problem.
Either way will work.
Friday, July 3rd, 2009 AT 6:55 PM
