I donated $10 by PayPal recently but have not received a reply so I assume you did not get my request. I recently rebuilt the heads and installed a new distributor. I initially had trouble geting the timing set but eventually got the engine started. After running the engine to get it hot, I set the valves per recommendations at one full turn after the rocker arm was tight. When I tried to restart the engine is would not fire and the timing was advanced by 20 or 30 degrees. How do I proceed now? Is this an indication of other problems?
Jan 8, 2008 at 11:37 AM
