1975 Chevy Camaro starter
RTHROOP
Engine Mechanical problem
1975 Chevy Camaro V8 Two Wheel Drive Automatic
just put in a new starter, used the shims in each and everyway. on the starter sound like it still stays on when I start the engine. What do I do????
Jan 23, 2010 at 9:52 AM
DOCFIXIT
  • 18,828 POSTS
Remove battery cable at starter connect remote switch to batt and solenoid terminal. Engage to move pinion gear out to fly wheel having loosened starter bolts bend up a paper clip adjust with shims until clip can be inserted between pinion and flywheel gear.
Jan 25, 2010 at 3:05 AM
