Electrical problem
1974 Chevy Camaro 6 cyl Two Wheel Drive Manual
When I turn the key to shut the engine off it does not shut off. I would have to turn it all the way back past lock to shut it off. Then I could not get the key out. Turn it forward to release the key and everything lights up as in the "ON" posotion. Now turning it all the way back won't work, I got it to stop by releasing the clutch and stalling but it wll not shut off so of course now the battery is dead. Does this have to do with the cylinder lock or the ignition switch. My manual says to get to the switch I have to drop the steering column.
Nov 22, 2008 at 10:53 AM
