New motor 350 creat motor came w/all intenal part from speed shop. New carb only has 2 vac, lines, adv, to upper part of card and 1 to lower part of carb.
CXhecked spark plug wires fire order from left to right. Cyls. 2, 4, 6, 8, 1, 3, 5, 7 them I check plug wires to cap. Starting left to right is correct. HELP
SPONSORED LINKS
Saturday, May 10th, 2008 AT 9:38 PM
MASTERTECHTIM
MECHANIC
Is your question. Car backfires when cold? Does it run ok when warm? If it does then you need to put a choke on the carb for the cold starts, your getting a lean backfire.
