1971 Chevy Camaro h.e.i
2,700 MILES • V8 • 2WD • AUTOMATIC
PATRICK VOSS
i HAVE A 1971 CAMARO 350CID. I have installed a new m.s.d. box. After all the mods and adding extra grounds I can't get the car tostay running more than 10 seconds. If I retur key to start place it will fire rightup. but unless I do it will act as if it has no spark. I have tryed all the truoble shooting in the book and called the teck line. Nothing works. I have switched coils aswell. Nothing. looked over wiring _nothing...
Feb 16, 2008 at 1:25 PM
DAN P
  • 9 POSTS
check to see if if you have b + while cranking and with key on, some spots on factory fuse box lose 12 volts while cranking [to protect elec components]also you cant have any large current wires next to any msd pickup wires.
Mar 10, 2008 at 4:08 PM
