1969 Chevy Camaro water leak from timing cover
1969 CHEVROLET CAMARO
30,000 MILES • V8 • 2WD • MANUAL
PAUL MCANN
I have a water leak from the bottom of the timing cover. What could be the cause of this?
Also, how can I find out the year of the engine block?
Jan 2, 2010 at 8:55 AM
DOCFIXIT
  • 18,828 POSTS
Check to see if water pump to block gaskets are not leaking. look just after cylinder head bolted to block I think drivers side should be numbers stamped these will tell year of block
Jan 3, 2010 at 6:50 AM
