1969 Chevy Camaro Ingition Coil
1969 CHEVROLET CAMARO
75,000 MILES • V8 • 2WD • MANUAL
EZZ28
Hi all,
I had problem where had to replace my fuel pump. Fuel flows fine; but now the engine just won't start; I was wondering possibly if the ignition coil might be bad; I started off by adding starter fuild to carbulator; check fuel flow; can see fuel flowing thru fuel filter to carbulator. Was wondering if possibly the coil is bad. How can I test the ingition coil?
v/r
Kimo
Mar 7, 2008 at 5:52 PM
DAN P
  • 9 POSTS
Stick a spark plug on the end of the coil wire, crank it see if it sparks.
Mar 10, 2008 at 3:10 PM
