my 69 camaro will not start after i started it and let it run out of fuel i put more in it but it will not start still
Feb 7, 2010 at 5:22 AM
JDL
✓Experienced Mechanic
Hi, did try a little gas down the throttle bore? Engine cranking, is there spark at the plugs? If you take the supply line loose from the carb and aim into proper container, anything come out when you crank it? Try not to get gas everywhere, you don't want to start a fire.
