1969 Chevy Camaro engine mounts
IANO
Engine Mechanical problem
1969 Chevy Camaro V8
Hi was wondering if anyone had any idea how to get he bolts undone on the engine mounts on a 69 camaro.any tips ideas anything would be appreciated. I have a cracked engine mount that needs changing and am at my wits end with it. none of the areas have enough room to get regular tools into thought maybe there was a specialy designed tool.
Feb 22, 2010 at 2:19 PM
HMAC300
  • 48,601 POSTS
this is real simple, but better done on a hoist. You jack the engine up with a movable jack stand then use a universal to remove the bolts and bolt the new one in then let it down and bolt the nut on the mount..
Feb 25, 2010 at 12:38 PM
