1968 Chevy Camaro spark, but no power on one cylinder
89,000 MILES • V8 • 2WD • AUTOMATIC
CHUCK GORDON
#5 cylinder has spark to the plug, 125lbs of compression with remaining cylinders all within 10lbs, #5 cylinder will not produce power at any speed.
Enriching fuel mixture creates approximate 10rpm gain, but still no power to #5 cylinder.
No vacuum leaks found.
What other additional diagnosis can I perform that will help in resolving my problem?
Thanks, chuck
Jan 14, 2008 at 10:17 AM
MASTERTECHTIM
  • 4,750 POSTS
what about a worn camshaft lobe on the exhaust valve. id remove valve cover and watch the rocker arm. see if 1 does not move as well as the others. i hope this helps.
Jan 14, 2008 at 10:22 AM
BLACKOP555
  • 10,386 POSTS
Well check for pulse at the fuel injector, also try switching it with another injector and see if the problem moves with it.
Jan 14, 2008 at 10:23 AM
