1967 Chevy Camaro breaking starters
75,000 MILES • V8 • 2WD • AUTOMATIC
SCRUFFY290
I've had 3 starters break in the last 6 months. The timing is correct. It seams like I can't get the shims right but I don't know how to set them corectly. Also one of the mounting screws is bent a little but not much. I also wonder if it should have a rear mounting bracket. Mine does not.
Jul 17, 2009 at 12:17 PM
LOUT5369
  • 217 POSTS
First get yourself some new bolts,any parts store will have them,that rear bracket you refer to is there for 2 reasons starter support and as a heat sink,they're nice to have.What shape is the flywheel in?when you shim the starter install starter with no shims,take an 1/8 inch drill bit and check drive clearance between drive and fly wheel start with thin shims.Good Luck,Lou
Jul 22, 2009 at 3:52 AM
