1967 Chevy Camaro brake lights
K9ARKO
  • 1967 CHEVROLET CAMARO
Brakes problem
1967 Chevy Camaro V8 Manual
Ok, I have a stumper. My drivers side brake light works, the passenger side does not. When I turn the head lights on at night the passenger side does not work still, and the drivers side that was working, no longer works, no parking lights in rear either when head lights are on. Any ideas, electrical problems like this drive me crazy. Thanks guys.
Wednesday, August 11th, 2010 AT 4:47 AM
JDL
  • 16,098 POSTS
Did you check all the bulbs, and voltage circuits? The brown wire is voltage for tail-lamps, goes hot when you turn on the headlamp switch. The other color wire should be brake/turn, they use the same bulb filament, just not at the same time. The brake lites are wired through the turn switch.
https://www.2carpros.com/forum/automotive_pictures/170934_camaro_stop_and_turn_lamps_1.jpg
Wednesday, August 11th, 2010 AT 10:33 AM
